Date/Time: Sun, 04 Oct 2026 11:54:15 +0000
OCO Orders
View Count: 1690
| [2013-05-08 16:56:19] |
You need to add these commands through Global Settings >> Customize Chart Trade Menu. Refer to the documentation here (step 11): http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#EnteringOrdersFromTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
