Date/Time: Thu, 19 Nov 2026 13:37:32 +0000
2nd sierra installation
View Count: 712
[2024-08-06 15:50:42]
User203340 - Posts: 15
I downloaded 2nd sierra installation and when I opened it all the numbers and letters are in big and bold.Is there a way change it . attaching picture of it.
image17229591963837990734235581836606.jpg / V - Attached On 2024-08-06 15:47:17 UTC - Size: 4.02 MB - 172 views
[2024-08-06 17:24:20]
First, if you want to have the same Global Settings as you had set in your other installation, then copy the "Sierra4.config" file from the old installation to the new one. Be sure Sierra Chart is not running in either installation. The file is located in the main Sierra Chart installation folder. Refer to the following for information on transferring this, and other files, between installations:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
Second, if you just want to adjust the fonts on that system without transferring the file, then adjust the "Fonts" by selecting "Global Settings >> Graphics >> Fonts". Refer to the following:
Graphics Settings: Fonts
