Date/Time: Thu, 19 Nov 2026 14:42:00 +0000
Adjust drawing after stock split by a multiple
View Count: 604
[2024-06-12 04:40:52]
User346098 - Posts: 50
would like to request a feature, if not too much trouble, for Tools -> Manage Chart Drawings Window -> Adjust
in addition to the positive/negative value for adjusting drawings by adding/substracting by that tick amount, also add for adjusting using a multiple number
per example if there is a stock split 10:1 one could use *0.10
if split is 1:10 then adjust by using *10
if using * as prefix to the value is ugly then maybe add a new row for the multiple value, you decide.
Some charts can get 100+ drawings and going one by one is tedious,
Thanks.
