Date/Time: Thu, 19 Nov 2026 14:42:01 +0000
How do I change Ticks to Currency/Price on Dom
View Count: 961
| [2024-06-11 22:18:55] |
| alphanzo3287 - Posts: 1 |
Hi! I have a very basic understanding of Ticks and Points. And I don’t like using that format when I am trading, using them for my Take Profit and Stop Loss. I prefer to change it to currency because it will be easier for me to set my TP and SL without blowing my account and I am managing my risk properly. Can someone show me or explain how to change the Ticks and Points to currency for my TP and SL? Date Time Of Last Edit: 2024-06-11 22:19:58
| [2024-06-12 13:43:15] |
| John - SC Support - Posts: 48584 |
If you are referring to when you are entering the Targets and/or Stops on the Trade Window, then there is not a way to set a Profit/Loss there, as the system does not know what price you will enter your parent order. You can specify a "Price Offset" instead of Ticks. Refer to the following: Attached Orders: Offset Values If you are referring to how to view the Profit/Loss on the Targets/Stops order lines, then refer to the following for defining the P/L format for the chart: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) And refer to the following for displaying the Profit/Loss on the order lines: Global Trade Settings Windows: Attached Order P/L Always (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
