Date/Time: Thu, 19 Nov 2026 14:41:54 +0000
How to create a DOM for the NQ with Tick Compression
View Count: 2360
| [2024-06-11 18:54:17] |
| User492282 - Posts: 15 |
Good morning Sierra Charts Support, how to create a DOM for the NQ with "Tick Compression". - And Upload a picture! How does the SierraCharts process works in the background? - What do I have to do? Thank you |
| [2024-06-11 18:55:38] |
| John - SC Support - Posts: 48584 |
We think you are referring to the "Market Depth Combine Increment In Ticks". Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Also note the following setting: Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
