Date/Time: Thu, 19 Nov 2026 14:41:49 +0000
On Chart Symbol Change Does not Work
View Count: 471
[2024-06-11 17:38:56]
User428777 - Posts: 13
Whenever I type a symbol it goes to a completely different symbol. I attached a GIF showing this. MSFT goes to MSOS, BYND goes to DJI, GME_MBO goes to INO-NQTV etc.. In this state, I cannot effectively jump to tickers on the market. Is this an error in the feed?
imageglitch.gif / V - Attached On 2024-06-11 17:38:49 UTC - Size: 64.47 KB - 264 views
[2024-06-11 17:41:10]
John - SC Support - Posts: 48584
The way you enter the symbol using the keyboard input buffer depends on whether you already have data for the symbol or not. Refer to the instructions at the following link and the section below it:
Changing the Symbol of a Chart: Quickly Changing the Symbol of a Chart to a Symbol for which a Data File Exists
