Date/Time: Thu, 19 Nov 2026 14:41:59 +0000
Trade menu quantity buttons
View Count: 935
| [2024-06-10 23:06:44] |
| Steve Leon - Posts: 319 |
I saw there is a selection for changing the color of the quantity button on the Trade menu under global setting but not on the Chart Trade DOM settings. I cant seem to get the color to change even when i am selecting it through global settings and checking global settings box ? Is it possible to change the color of the selected quantity button ? Thank you |
| [2024-06-11 14:31:26] |
| John - SC Support - Posts: 48584 |
If you are referring to the Quantity buttons on the Trade Window, then there are two coloring options in the Graphics Settings for these: - Chart Trade Window Quantity Buttons Color - Chart Trade Window Selected Quantity Button Color If you are changing the "Chart Trade Window Selected Quantity Button Color" and selecting Apply or OK, then you will not see the button change color immediately. You would need to change to a different quantity button in order for the color to take affect. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-06-11 15:41:31] |
After shutting down and restarting i see the selected quantity had changed to the color i had set it to. One question i still had is that i set this under global graphics settings but did not have the global graphics settings checked under the Chart graphics settings ? I was not sure how or why this was still displaying without the global settings box checked ? Thank you |
| [2024-06-11 16:16:45] |
There are some graphics items that are global in nature and therefore are not available in the chart specific graphics settings. This happens to be one of them. So the only place to change it is in the Global graphics settings.
