Date/Time: Thu, 19 Nov 2026 14:41:50 +0000
Show TItle Bar/Menu on DOM/Tape
View Count: 991
[2024-06-07 17:46:36]
User749040 - Posts: 45
Hello SC team, I have a question on the "Show Title Bar" and "Show Menu". When a Chart is detached you can hide both the title bar and the menu. When a DOM is detached you can only hide the title bar but not the menu and you can never hide the menu on the tape. (Screenshots attached)
When a DOM is attached, the menu can be hidden. Is it possible to add an option to remove the menu on the DOM when it's detached?
The tape menu is never hidden so if that can be added it would be also great.
Thank you.
Private File
Private File
[2024-06-10 21:29:40]
Any plans on this?
[2024-06-11 13:43:52]
John - SC Support - Posts: 48584
We take all requests/suggestions, but we can not say when we would get to any particular item.
[2024-06-11 17:57:53]
Thank you, I didn't know if there was an option to hide it and I didn't know it so mainly I was asking but yes it would be a great addition if you could add that.
