Date/Time: Thu, 19 Nov 2026 14:54:02 +0000
Graphics Settings - Chart other options are not available
View Count: 573
| [2024-06-03 16:06:43] |
| tradersis - Posts: 5 |
Hello I need to enable some options within "Other" tab in "Graphics Settings - Chart" but I don't any setting available for setting or unsetting. A screenshoot is attached for your reference. Please advice, thanks. |
| [2024-06-03 19:52:33] |
| John - SC Support - Posts: 48586 |
Those items can only be modified through the Global Graphics Settings. You are viewing the Chart Graphics Settings. Select "Global Settings >> Graphics Settings" to be able to change those items. Also refer to the following: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-06-04 09:11:11] |
That works! Thanks for your quick support. |
