Date/Time: Mon, 11 May 2026 20:02:05 +0000
Problem with VbP - One Period at End of Fixed Time Length - Auto-Skip Empty Days
View Count: 779
| [2024-05-28 07:52:23] |
| ticinotrader - Posts: 426 |
Dear Support, Can you please help me with the following issue? I am trying to display 'rolling' multi-day volume profiles on TPO charts. I have found a problem when using the Volume by Price study Volume Graph Period type: 'One period at the end for fixed time length - Autoskip empty days' I am attaching a chartbook and screenshots with an example of a 3 day volume profile. When I add it to a normal (non-TPO) chart, the volume profile is calculated correctly and is based on 3 days, but when I add the volume profile to a TPO chart with exactly the same settings, the volume profile is clearly wrong and contains much more data than 3 days. Is there any way to fix this or can you recommend a solution/settings to use to get the same profile to display correctly on a TPO chart? Thanks in advance for your advice. https://www.sierrachart.com/image.php?Image=1716882276970.png https://www.sierrachart.com/image.php?Image=1716882333755.png |
Private File |
| [2024-05-28 12:06:44] |
| Sierra_Chart Engineering - Posts: 23735 |
We will look this over, but we are so behind at this point in time, we do not know when we will get to it. At this point we have to be honest, allow several months at a minimum. We simply do not have the time for this now and the functionality you are looking for must be considered unsupported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-28 12:07:28
| [2024-07-04 14:48:36] |
We are resolving this now. Sorry for the delay. We need more holidays like this to catch up on tasks.
