Date/Time: Thu, 19 Nov 2026 15:28:13 +0000
Display label and value both on each candle using ACSIL
View Count: 797
| [2024-05-05 08:33:26] |
| User549631 - Posts: 2 |
Hello respected support, I can display value on each candle subgrapgh by DRAWSTYLE_VALUE_ON_HIGH (on each candle) but how can I put label with value. I have spent 3 days on it but still I cant find the answer. Would you help me please?
| Attachment Deleted. |
| [2024-05-05 08:41:06] |
I used LL_DISPLAY_NAME | LL_NAME_ALIGN_ABOVE but it shows only 1 label. I want label with valuie on each candle
| [2024-05-05 13:08:35] |
| Sierra_Chart Engineering - Posts: 25441 |
This is a Subgraph draw style: DRAWSTYLE_VALUE_ON_HIGH
This is unrelated and are labels which there can only be one of, independently for the name and value, in the chart for each Subgraph: LL_DISPLAY_NAME | LL_NAME_ALIGN_ABOVE
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-05 13:09:08
