Date/Time: Thu, 19 Nov 2026 16:12:21 +0000
2 different brokers
View Count: 579
[2024-03-26 02:32:54]
User955491 - Posts: 3
Am I able to use sierra chart with 2 different brokers with denali data feed teton order routing? Or would I need 2 data subscriptions? One for each broker?
[2024-03-26 14:05:01]
Yes this is supported:
You will want to install a second Sierra Chart to connect to the second broker. Refer to the following
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
