Date/Time: Sun, 19 May 2024 12:01:38 +0000
CQG trade problem
View Count: 2139
[2014-08-28 06:47:15] |
The update has been performed, however furthest forward futures contract we see for GE is September 2018. This is the furthest forward we can get for GE on the CME multicast feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-28 11:50:17] |
cmb999 - Posts: 211 |
I think I meant to say Z 16 in post 18. Thanks for the update. That is about half of the supposedly 10 yrs of forward expiration, which is fine for my purposes. As the contracts reach further out, there should be less data to store anyway. would appreciate also if you could fill out Fed funds till dec 2015, as well. thank you . . Date Time Of Last Edit: 2014-08-28 11:50:57
