Date/Time: Sun, 01 Nov 2026 02:45:18 +0000
Alert
View Count: 1206
| [2014-08-05 14:57:09] |
| User27486 - Posts: 2 |
When using the "Countdown Timer" study How can I create a SOUND alert to signal the end of a bar?
| [2014-08-05 15:35:14] |
You need to set the Alert on New Bar Input with the Countdown Timer study to Yes. Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s201 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-05 15:35:35
