Date/Time: Mon, 21 Sep 2026 19:39:26 +0000
Trade and Current Quote Symbol disappearing
View Count: 492
| [2024-02-13 16:00:52] |
| iamLL - Posts: 4 |
Hello, I've been experiencing some issues with my settings regarding the Trade and Current Quote Symbol that disappears for no obvious reason. This is the 2nd time it happens in 2 months, and I don't really know why it's happening. Unfortunately, I lost 2 prop firms accounts on Friday trading minis instead of micros, and 6 in the beginning of January... I really would like this to not happen again. Is it possible to give me some help on this topic? I tried to reproduce the issue without success. Thank you in advance for your help. |
| [2024-02-13 16:06:17] |
| John - SC Support - Posts: 47955 |
The only reason for the "Trade and Current Quote Symbol" to be removed is if you have changed symbols and you have the option for "Chart >> Chart Settings >> Clear Trade and Current Quote Symbol on Symbol Change" set to "Yes". Refer to the following: Chart Settings: Clear Trade and Current Quote Symbol on Symbol Change (Chart >> Chart Settings >> Trading menu) Also, keep in mind you can setup a "Trade and Current Quote Symbol" in the "Symbol Settings", if you are always using this. Refer to the following: Global Symbol Settings: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
