Date/Time: Thu, 05 Nov 2026 17:44:40 +0000
Chart trading dom bid and ask color change
View Count: 692
| [2024-02-05 06:04:44] |
| User193762 - Posts: 18 |
Hello Where can I change color of bid and ask (Resting orders) for Chart trading dom? My background is black and looks like font is black. |
Private File |
| [2024-02-05 15:07:51] |
| User43 - Posts: 102 |
Either in Global Settings >> Graphic Settings - Global Or with the chart selected in Chart >> Graphic Settings - Chart Scroll down to the "Chart DOM ..." section and look for the rows which have "Text" in their title. There are about 10. two of them should be what you are looking for. |
| [2024-02-05 17:49:26] |
| John - SC Support - Posts: 48447 |
Refer to the following: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Ask Depth Quantities But most likely these are not set to black, but rather you have the wrong columns. Refer to the following: Global Trade Settings Windows: Buy Order Column - Left/Center/Right Aligned For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
