Date/Time: Thu, 05 Nov 2026 17:44:32 +0000
[User Discussion] - have error when applying number bar (studies)
View Count: 507
[2024-02-05 02:35:19]
Ngalylomqua - Posts: 4
The log said service package doesnt support this function or account is expired. and i would like my chart to look specifically like this one is it possible?
[2024-02-05 17:36:16]
You are on Package 3 (Base Standard). This package does not allow for the Numbers Bars study. You would need to change to Package 5 (Base Advanced) in order to have the Numbers Bars. Refer to the following:
Description of Service Packages and Pricing: Base Packages
To change your package, follow these instructions:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
