Date/Time: Fri, 13 Nov 2026 21:11:08 +0000
DTC C# code on github
View Count: 4310
[2014-08-01 05:17:23]
onnb - Posts: 666
hi, first, is this forum the right place for DTC related questions/issues/discussions?
I cloned the DTC C# example and header file (DTCProtocol project).
I am able to use this code and connect with SC as a service provider.
Is the repo managed by Sierra Chart? I added to the header file a new structure for logon response and want to see if there is interest that I push it back up.
[2014-08-01 16:09:44]
ejtrader - Posts: 689
onnb - Certainly would be helpful - if you could upload it or make it available somewhere here.
[2014-08-01 16:20:35]
ganz - Posts: 1048
SC Support
btw It would be good to see it cross platform and easy to use: I mean DTC python wrapper.
thnx
Date Time Of Last Edit: 2014-08-01 16:21:00
[2014-08-01 17:47:47]
onnb - Posts: 666
ejtrader - are you referring to the header or the server code? I see these as two separate pieces.
Have you downloaded and tried running the github project from here: https://github.com/SierraChart/CSharp-DTC-client
That implements a client but some of the code from it can be used for a server which is what I am currently writing.
The server code I have is just integration code implementing a service provider in c# - it has no error handling, it is not scalable and it doesn't do much ;) It just starts listening, responds to logon requests, sends heartbeats and logs new client requests as they come in.
After I clean them up a bit, I'll gladly post them both.
[2014-08-01 18:01:30]
Thanks Onnb. just looking for a starting point on this to expand further :)
[2014-08-02 06:48:19]
onnb - Posts: 666
see here: https://dl.dropboxusercontent.com/u/9913454/tmp/DTCServer.zip
It includes a winforms project of a simple server that listens for requests. Logon requests are returned successfully and a heartbeat message is sent to the client. Market data requests are rejected because I wanted to write a server that provides historical data only. I am still not receiving the historical data request from sc but that is another matter.
Also note that the project includes an updated version of the c# header file that I found in the https://github.com/SierraChart/CSharp-DTC-client project.
[2014-08-02 07:00:28]
Thanks Onnb. Appreciate you sharing this. Would check out and see if I can expand further on this.
[2014-08-05 07:46:35]
Yes.
Yes.
[2022-12-04 13:02:24]
User223231 - Posts: 21
The Sierra Chart GitHub page does no longer have the C# DTC client project. Is it available elsewhere?
Date Time Of Last Edit: 2022-12-04 13:02:41
