Date/Time: Fri, 23 Oct 2026 21:45:17 +0000
Finish Delta
View Count: 11638
[2016-03-18 16:50:28]
2garin - Posts: 189
Good Day a support.
When you create (compared to) similar charts of MD in the indicator Numbers_Bars_Calculated_Values errors appear. The errors related to the calculation of the parameter "Finish Ask Volume Bid Volume Difference (Finish AskVol BidVol Diff)". When you create a chart completely removed and re-loaded historical data.
Probably the screenshot you can help localize the error.
Date Time Of Last Edit: 2016-03-20 14:38:42
image55.jpg / V - Attached On 2016-03-18 16:49:58 UTC - Size: 287 KB - 1108 views
image56.jpg / V - Attached On 2016-03-18 16:57:18 UTC - Size: 115.26 KB - 1020 views
image57.jpg / V - Attached On 2016-03-20 14:38:35 UTC - Size: 265.8 KB - 1682 views
[2016-03-18 17:33:20]
We need some time to look over post #25.
[2016-03-22 07:42:21]
gomifromparis - Posts: 244
Hi
Any news on the finish and the 'last touched min or max delta'? Solution to #25 might probably be #21.
[2016-03-22 10:21:35]
We will have this done by the end of the week.
[2016-03-23 04:37:13]
This new Base Data array will be out in the next release:
SC_ASK_BID_VOL_DIFF_MOST_RECENT_CHANGE
We will also be updating the calculation of:
[2016-03-25 05:57:15]
This has been solved.
[2016-03-25 07:56:34]
It compiles but since the header version is 1388 and the build version is 1387 , it won't execute
[2016-03-25 11:50:58]
got it to run by replacing 1388 by 1383 in the header. seems the internal build of the release is too low, 1387 and 1385 didn't work
[2016-03-25 15:30:16]
This will be solved later today.
[2016-04-01 02:45:44]
2garin - Posts: 189
1389 Release Date: 2016-03-29
Numbers Bars Calculated Values study Finish calculations have been updated.
I use version 1390. The differences remained.
image1390.jpg / V - Attached On 2016-04-01 02:43:21 UTC - Size: 243.97 KB - 744 views
[2016-04-01 06:27:49]
could you post a minute-based chart ? I'd like to test against a ninjatrader version.
[2016-04-01 06:39:01]
2garin - Posts: 189
no problems
image1m.jpg / V - Attached On 2016-04-01 06:37:33 UTC - Size: 237.3 KB - 1039 views
[2016-04-01 06:41:33]
could you post the MD version for comparison ?
[2016-04-01 06:45:20]
2garin - Posts: 189
I do not use MD. I want to implement a trading method implemented in the MD.
[2016-04-01 08:47:18]
What is the platform you are comparing the numbers to then?
On Ninja I compute the finish as per the MD specification tick by tick and I find the same as sierra numbers (shown on bottom of each candle)
So have we misread something ???
imagesierrafinish.png / V - Attached On 2016-04-01 08:47:13 UTC - Size: 190.04 KB - 1008 views
[2016-04-01 09:02:24]
Okay so according to post #39, there are no problems with the "Finish Ask Volume Bid Volume Difference" calculations?
[2016-04-01 09:12:03]
For me it corresponds to the definition in #21
[2016-04-01 11:24:51]
ganz - Posts: 1048
SC Support
what does it mean exactly? what did you do?
[2016-04-01 11:33:09]
they applied algo mentioned in #21, which is different from the algo mentioned in the beginning of the thread, which was using max absolute values of mindetla and maxdelta
[2016-04-01 11:46:48]
ganz - Posts: 1048
gomifromparis
OK. Thnx.
So the study description should be corrected as well, imo
[2016-04-04 10:06:24]
The documentation will be updated later today.
