Date/Time: Sat, 14 Nov 2026 17:53:51 +0000
How to avoid of canceling limit order first,then go market?
View Count: 632
| [2023-09-09 10:24:28] |
| User438057 - Posts: 51 |
How to exit or open a position with a market order without the need of cancel an existing limit oder first, if in -Symbol Settings- Trade Position limit is set to 1? So, If i change my mind and want to get filled immediately, I dont want to cancel the existing limit order first and then place the market order, instead SC should cancel the limit order automatically when I place the market order. I dont want to increase the trade position limit to avoid this problem, because this could lead accidentally to a position greater than 1. I appreciate your help. Thanks |
| [2023-09-10 07:34:01] |
The solution I have found is to move my existing limit order towards the price so far that it gets filled at Market. Under Customize Keyboard Shortcuts--Trading Keyboard Shortcuts-- Non-attached Limit Order Tick Up/ Non-attached Limit Order Tick Down will do the job. Problem solved. |
| [2023-09-10 15:27:55] |
| user_xyz - Posts: 529 |
This is what I do, found it to be the fastest way.
