Date/Time: Sat, 14 Nov 2026 17:54:03 +0000
Control Bar - Button
View Count: 624
| [2023-09-08 14:45:25] |
| User92573 - Posts: 622 |
Dear Support Board For sometime I've used the NEXT button to go to the next workbook as opposed to the F keys. However, I'm going blurry eyed trying to it in the Available Control Bar Commands. I've googled it as well but to no avail. Maybe it's because its Fridays? Any help/direction as the location/category much appreciated. |
| [2023-09-08 15:35:38] |
| John - SC Support - Posts: 48527 |
If you are looking for "Next Chartbook" in the Control Bar Commands, it is under the "Window" section on the "Customize Control Bar" window. When you open the section for "Window" and start scrolling down, you will see a collection of "Control Bar x" items. The Next Chartbook option is 5 items down from the last "Control Bar 8" item. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-09-08 17:27:43] |
Thank you John. Looked everywhere just couldn't see it. Probably the heat.
Date Time Of Last Edit: 2023-09-08 17:28:15
