Date/Time: Sat, 14 Nov 2026 18:13:48 +0000
GRAPHICS_SETTING_CHART_TRADE_WINDOW_BACKGROUND is missing
View Count: 699
| [2023-08-09 20:26:18] |
| User1293821 - Posts: 42 |
"GRAPHICS_SETTING_CHART_TRADE_WINDOW_BACKGROUND" is missing from GraphicsSettingsEnum in scconstants. "GRAPHICS_SETTING_CHART_TRADE_WINDOW_BACKGROUND_SIM" is there. *edit - it appears a lot of the colors are not being updated when calling the function sc.SetGraphicsSetting on the pre-release or 2528. Its vague but "GRAPHICS_SETTING_CHART_TRADE_WINDOW_BACKGROUND_SIM", "GRAPHICS_SETTING_BID_ASK_BAR_ASK_LARGE", "GRAPHICS_SETTING_RECENT_BID_VOLUME", are a few examples. Would be great to get that added. Thanks! Some wishlist features 1. Set the global graphics config number and/or edit global colors similarly to the way you can with the chart. When making global graphic configs its a pain to edit all green colors to all blue. 2. Setting font names and sizes programmatically would be appreciated. I go from a 4k 43in tv to a 1080p monitor and manually have to switch all the font sizes is mundane. Date Time Of Last Edit: 2023-08-09 20:59:37
| [2023-08-12 17:14:18] |
| Sierra_Chart Engineering - Posts: 25425 |
These issues have been resolved in the latest prerelease. 2. We are working on a solution for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-08-12 17:29:07] |
| JohnR - User831573 - Posts: 340 |
Maybe having multiple profiles you can load/save for all of the global options. It would be great to additionally to be able to load/save a subset of 'All' global options. JohnR |
