Date/Time: Sat, 14 Nov 2026 18:23:53 +0000
TETON MARGINS
View Count: 1301
| [2023-08-09 12:26:50] |
| User480489 - Posts: 1 |
WHERE I CAN FIND MARGINS FOR TETON/ AMP? AMP HAS $50 PER MICRO - I JUST GOT $420 FOR MICRO - WHAT IS THE DEAL HERE..? THANKS |
| [2023-08-09 14:29:42] |
| Sierra_Chart Engineering - Posts: 25425 |
Your broker controls margins. Sierra Chart has no control over this. You need to contact them about this. However, you can check what the actual assigned margins are as explained here: Trade Account and Risk Management: Viewing Margin Requirement for Symbol and Trade Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
