Date/Time: Sat, 14 Nov 2026 18:23:37 +0000
maket depth historical graph
View Count: 692
| [2023-08-03 16:18:00] |
| User774712 - Posts: 13 |
can someone explain to me why it does this, i don't understand how to fix it, it does this again and again?
| [2023-08-03 17:56:27] |
| John - SC Support - Posts: 48527 |
What are the following Inputs set to on your Market Depth Historical Graph: - Extend Last Known Depth: - Number of Minutes to Extend Last Known Depth (0 for All) - Maximum Levels to Display (0 for All) - Combine Increment in Ticks - Automatic Combine Increment Adjustment Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-08-03 18:24:10] |
- Extend Last Known Depth: YES - Number of Minutes to Extend Last Known Depth: is already 0 - Maximum Levels to Display : 0 - Combine Increment in Ticks: 1 - Automatic Combine Increment Adjustment Value: 0 |
| [2023-08-03 18:42:22] |
Please get us a copy of that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-08-03 19:17:11] |
i don't know how or why but it's been working fine for the past 2 hours, i'll attach the chartbook anyway.
| [2023-08-03 20:06:56] |
The most likely culprit is the "Lowest Quantity for Coloring" as you have this set to an "Actual Value" of "40". So any time a Market Depth level is less than 40, it will not display.
