Date/Time: Sat, 14 Nov 2026 18:23:38 +0000
Taille des tpo trop petite Nasdaq
View Count: 678
[2023-08-03 05:11:08]
User532215 - Posts: 2
Bonjour,
Pour l'indice nasdaq future
Les tpo sont trop petit
Ou illisible
J'ai bien modifié le réglage increment
Mais du coût le prix d'une lettre ne correspond pas a 1 tick
De ce fait l analyse est incertaine
Avez vous une aide à me proposer ou un réglage ?
Merci par avance
[2023-08-03 14:32:33]
From Google Translate:
For the nasdaq future index
The tpo are too small
Or illegible
I have changed the increment setting
But of the cost the price of a letter does not correspond to 1 tick
Therefore, the analysis is uncertain.
Do you have any help for me or an adjustment?
We would really need to see an image to ensure that we are fully understanding, but from what you say, the only option is to adjust the "Letter/Block Price Increment in Ticks". This combines multiple price levels to allow you to view the individual letters/blocks.
You can also try scaling the chart, but if the blocks are really too small, then the above is the only solution.
