Date/Time: Wed, 30 Sep 2026 02:43:22 +0000
ø
View Count: 538
[2023-06-14 21:55:24]
sgne - Posts: 109
ø
Date Time Of Last Edit: 2024-12-05 04:18:40
[2023-06-15 17:52:44]
Sierra_Chart Engineering - Posts: 25005
This is not something we have time to get involved with. It is not likely we would make any changes to this anytime soon and we would probably not even be looking at this for years from now. You will need to develop your own functionality to accomplish what you want. Do not use those cells if they do not do what you need.
[2023-06-16 08:19:53]
If anything we should just remove the functionality. It was added for a user request. And is not something that cannot really work reliably. We should just simply remove it. We do not recommend using it.
Date Time Of Last Edit: 2023-06-16 09:50:58
[2023-06-16 13:15:06]
Sawtooth - Posts: 4355
Please don't remove this functionality.
It works fine when not using scale in/out.
[2023-06-16 14:37:05]
Ok we will not. Documentation has been updated.
[2023-06-26 07:38:43]
No there is definitively no error. Pay no attention to that field. Obviously it does not do what you want. Just ignore it.
