Date/Time: Wed, 30 Sep 2026 01:04:50 +0000
Moving multiple drawings
View Count: 766
| [2023-06-07 12:44:56] |
| countryboy92 - Posts: 119 |
I have multiple drawings (text boxes, etc) that I would like to select a group of these text boxes and move them to a different location on the chart - is there a way to do this? It would take too much time and effort to move each text box separately to the new location on the chart window.
| [2023-06-07 12:54:54] |
| Sierra_Chart Engineering - Posts: 25005 |
You can change the vertical position by a fixed amount up or down. Refer to: Changing to a New Futures Contract Month: Adjusting Chart Drawings to Match Futures Contract Rollover Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
