Date/Time: Wed, 30 Sep 2026 01:07:21 +0000
Swing High and low study values
View Count: 1135
[2023-06-06 16:27:52]
User768094 - Posts: 2
Is there a way to print the distance from the previous swing high/low in ticks on the study instead of a marker (arrow/line...)?
[2023-06-06 17:05:37]
John - SC Support - Posts: 48062
You would have to use the Spreadsheet Study to determine the distance and then display that information instead of the Swing High/Low. Refer to the information here:
Using the Spreadsheet Study
[2023-06-06 20:14:34]
Sawtooth - Posts: 4355
Start with this example:
Spreadsheet Example Formulas and Usage: Return Last Two Zig Zag Reversal Values
Then use other Formula Columns to find the difference between values, then print them using Value On High, Value On Low draw styles.
