Date/Time: Fri, 13 Nov 2026 23:38:44 +0000
Detect a SG1 displayed on chart with Formula syntax
View Count: 1093
| [2023-06-05 19:14:10] |
| Nicolas Leclercq - Posts: 22 |
Hi, How can I detect a subgraph SG1 in a study with a formula syntax: example, ID16.SG1 is displayed on tha chart ...and i want to put a Trading system alert condition, with Formula syntax to trigger a trade, example : =(ID16.SG1>0) is my condition to Enter a position, but it doesnt work Thanks Nico |
| [2023-06-05 19:38:23] |
| j4ytr4der_ - Posts: 947 |
You don't need the parenthesis, though they shouldn't cause a problem. As long as ID16.SG1 is indeed returning true or false, then simply ID16.SG1 = TRUE
or ID16.SG1 > 0
should do it. Just make sure in the Trading System Based On Alert Condition study, you've set it to a buy or sell entry, whichever is appropriate for your needs. Here are the Long entry input settings for one of my bots. https://snipboard.io/HiNsTB.jpg |
| [2023-06-05 20:14:48] |
Thanks for your help It works with one SG 1/ I test with multiple SG: =OR(AND(ID16.SG1 = TRUE,ID11.SG1=TRUE),AND(ID13.SG1=TRUE,ID11.SG1=TRUE)) and it doesn't work 2/ When the position is triggered, the TP and STOP dont display, i thought it trigger my Targets (TP and STOP) of the Trade Window Date Time Of Last Edit: 2023-06-05 21:07:06
| [2023-06-05 20:53:19] |
What exactly doesn't work? What happens? Are you certain all of those subgraphs are in fact returning true? My guess is, something isn't returning what you think it's returning. To diagnose these things, I always check each subgraph one at a time in a spreadsheet study, just to see the returned output and make sure it's what I expect. |
| [2023-06-05 21:11:42] |
Is there a way to see the values of each SG in a window via the bar menu...i dont find where i have to seek
| [2023-06-05 21:13:09] |
Put each one in its own spreadsheet formula, and use the Chart Values Window to see them all at once (Window menu)
| [2023-06-05 21:23:30] |
I have tested...but nothing spreadsheet formula: I have tried with ID16.SG1=TRUE I have tried with ID16.SG1>0 i dont know why Result 0 always and i dont find where is Chart value window popup see screenshot Date Time Of Last Edit: 2023-06-05 21:34:44
| Attachment Deleted. |
