Date/Time: Wed, 30 Sep 2026 00:27:11 +0000
Seconds Chart
View Count: 2830
| [2023-06-05 18:39:02] |
| User547668 - Posts: 1 |
Hello, how can I set my chart to a smaller timeframe than 1 minute, for instance if I want to have every 15 seconds a new candle. Is this possible? Thank you very much for your help. |
| [2023-06-05 19:39:23] |
| j4ytr4der_ - Posts: 947 |
just type 15s or 5s or whatever you want in seconds in the chart. You can also open the chart settings and change it to 0-0-15 but I find typing is much faster.
| [2023-06-06 13:39:19] |
| John - SC Support - Posts: 48062 |
The following documentation gives you all the ways to change the bar period: Changing Chart Bars Period For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
