Date/Time: Wed, 30 Sep 2026 00:27:11 +0000
TPO Chart - Exclude ALL Evening Sessions
View Count: 1390
[2023-06-05 15:50:23]
User688525 - Posts: 401
Hello Sierra Chart,
Is it possible to exclude ALL evening sessions from a TPO chart if "Use Evening Session" is enabled? When the "Exclude Evening Session Profiles Except For Last Day" is enabled, all evening sessions except for the most recent are displayed, however, is it possible to hide ALL evening session, including the most recent session without having to disable "Use Evening Session?
Currently I have two TPO charts - one for the cash session and the other for both the cash and overnight. It would be ideal if I can remove one of the TPO charts so that a single chart can display both based on the TPO Study collections, not enabling/disabling the evening session.
If this functionality doesn't currently exist, can be added to the next version of Sierra Chart? If not, what ACSIL command would be required to exclude the most recent evening session?
Note, although a custom study can be used to enable/disable "Use Evening Session", if this is done instead of simply hiding the the TPO profile, the TPO chart reloads and recalculates the data each time. This is something I would like to avoid, particularly if displaying a couple of years of data on the TPO chart.
Thank you
Date Time Of Last Edit: 2023-06-05 16:28:28
[2023-06-05 16:41:24]
John - SC Support - Posts: 48062
This functionality does not exist. You would have to have the 2 charts as you do now.
[2023-06-05 23:16:41]
Hello John,
Thank you for confirming.
Can this be added as a feature request?
Also, is there a way to use ACSIL to exclude all, or the most recent evening session?
Date Time Of Last Edit: 2023-06-05 23:56:23
[2023-06-06 10:00:57]
Sierra_Chart Engineering - Posts: 25005
There is 0% chance of this being implemented.
No ACSIL is not going to help with this. Unless maybe you were to create custom chart bars:
ACSIL Interface - Custom Chart Bars
Date Time Of Last Edit: 2023-06-22 10:21:23
[2023-06-06 11:10:37]
