Date/Time: Wed, 30 Sep 2026 00:26:36 +0000
Watchlist
View Count: 802
[2023-06-04 22:12:28]
SR - Posts: 2
Is there any way to adjust the font size on the watchlist?
imageWatchlist.png / V - Attached On 2023-06-04 22:03:40 UTC - Size: 19.83 KB - 317 views
[2023-06-05 01:23:00]
58LesPaul - Posts: 429
Global Settings > Graphic Settings > Fonts > Quote Board
[2023-06-05 02:44:29]
SR - Posts: 2
@58LesPaul. Thank you so much for your reply but that does not work. From there I was able to adjust the font size of the Quote Board Font, but not the watchlist font.
[2023-06-05 10:20:23]
My bad! I believe you'll have to change the Control Bar text for all the buttons.
[2023-06-06 08:54:52]
Sierra_Chart Engineering - Posts: 25005
If you update to the latest version there is this new font setting:
"Control Collection Non Button Combo Controls (Global)".
You may have to hide the Control Bar and reenable it to cause the change to go into effect.
Date Time Of Last Edit: 2023-06-06 08:55:16
