Date/Time: Wed, 30 Sep 2026 00:27:13 +0000
[Programming Help] - Draw Value Areas and PoC from day before
View Count: 1739
[2023-06-04 20:25:51]
af_99 - Posts: 27
I would like to see drawed in a 3min chart (and have it in spreadsheet to use it) the VAH and VAL and PoC for the last RTH session (I mean, not today's session but yesterday's). I think it has to be with "Volume Value Area Lines" study, but I frankly cannot get what I want by changing settings.
Any idea how to do it?
Thank you very much.
[2023-06-05 15:11:48]
John - SC Support - Posts: 48062
What study you use depends on how your charts are setup.
If you have a chart that is just the RTH, then the "Volume Value Area Lines" study is the right one. Set the following Inputs as follows:
- Time Period Type: Days
- Time Period Length: 1
- Reference n Periods Back: 1
But if you have a chart with both RTH and ETH, and you just want the RTH, then you would need to use the "Volume by Price" study and set the following:
- Draw Mode: POC, VAH, VAL, VWAP Lines Only
- Number of Periods Back to Reference: 1
- Volume Graph Period Type: One Period from Start Time to End Time
- Start Time: Your RTH Starting Time
- End Time: Your RTH Ending Time
