Date/Time: Wed, 30 Sep 2026 00:27:14 +0000
Smaller numbers
View Count: 553
| [2023-06-04 18:38:09] |
| Daniel KamiĆski - Posts: 25 |
hello, is it possible for the numbers in Delta, Cum Delta and Total Vol to be in the format of candlesticks? Thank You |
| [2023-06-04 18:44:44] |
| j4ytr4der_ - Posts: 947 |
A side note for whatever it's worth, volume information in crypto is completely unreliable/trash. Beware relying on it.
| [2023-06-05 15:03:01] |
| John - SC Support - Posts: 48062 |
We are not sure exactly what you are looking for, but you can create Candlesticks from study information by using the "Spreadsheet Formula (Bar)" study. It works the same as the Spreadsheet Formula, only you can specify formulas for each of the Open/High/Low/Close to create a bar. Refer to the following: Spreadsheet Formula For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
