Date/Time: Fri, 13 Nov 2026 23:38:43 +0000
Spreadsheet System/Alert
View Count: 1428
[2023-06-03 22:30:53]
Nicolas Leclercq - Posts: 22
1. I made an Alert formula in a Color Bar Based on Alert Condition study,thats great its work ^^ : it is dispayed the SG1
2. I want to add this Alert in a spreadsheet SystemAlert, in order to detect when the SG1 of the ColorBarBasedonAlertCondition displayed on Chart, because i want to implement the column K : "Buy Entry" with the SG1 displayed
3. The trade will be begin with this Buy Entry
Question: In the spreadsheet, thers is no value in the column "SG1 Color Bar", i thought to see 0 (for false=SG1 no displayed) // 1 (for true=SG1 displayed on the chart)
I need help please
Nico
imageSharedScreenshot.jpg / V - Attached On 2023-06-03 22:29:47 UTC - Size: 58.76 KB - 388 views
[2023-06-04 13:59:19]
j4ytr4der_ - Posts: 947
This is hard to troubleshoot just from your description alone. Would help a lot to see whatever formulas you are using currently. Alert Formula syntax is slightly different from Spreadsheet syntax, so that's a consideration as well.
Make sure also that the study you want to include has the "include in Spreadsheet" box ticked, and the subgraph is not set to ignore, if you also use the "Do not output studies set to ignore" option in the spreadsheet (which I always do, personally)
[2023-06-05 06:42:08]
Hi j4ytr4der_,
Thanks for replying, it works with "Do not output studies set to ignore" to YES ^^
I've got another question: i want to automate my spreadsheet alert with "Spreadsheet for Trading"...my Buy/Sell Entry works with the good syntax in K3 and M3, and want to trade out with the Trade Window (with stop and BE strategy)
But when I replay, the order doesnt fill (but in my spreadsheet Trading: I see K3=1 or M3=1)
sees screenshot
Thnks for your help
Nico
imageTradeWindow.png / V - Attached On 2023-06-05 06:41:59 UTC - Size: 150.35 KB - 253 views
[2023-06-05 08:37:31]
Sierra_Chart Engineering - Posts: 25424
Do you still need help with this:
Scroll down through that column to see if you see any data because the Color Bar Based on Alert Condition study does not calculate from the very beginning of the chart. It has a Number of Bars to Calculate input.:
Color Bar Based on Alert Condition: Number of Bars to Calculate
