Date/Time: Fri, 13 Nov 2026 23:38:43 +0000
Selecting commands by keyboard, example after F5 chart settings
View Count: 682
[2023-06-03 01:06:31]
User34124 - Posts: 289
Then I'd press tab 14 times, the 'Invert Prices' row is highlighted. How does one select/toggle this with the keyboard?
[2023-06-03 20:30:01]
JohnR - User831573 - Posts: 340
You might want to consider a keyboard / mouse macro program. I use AutoHotKey AHK. As you are learning or get stuck, the forums are quick and helpful. I use it for simple things. Things I do often, Like switch from where ever my pointer is, It moves to the end of a specific chart and emulates Control End. I do this with a macro run when pressing Alt key and Left Mouse Button. -- Alt Right M B does something else.
Hope this helps,
JohnR
[2023-06-05 11:14:01]
Thank you John. Been checking it out. How would one select that row with AHK? I would assume a "ControlSelect" or some sort of alternative to "send {enter}", but noting works?
