Date/Time: Wed, 30 Sep 2026 00:27:14 +0000
Choosing the correct Datafeed in AMP
View Count: 637
[2023-06-02 05:47:36]
User952540 - Posts: 4
I am using Package 11 in Sierra Chart and I need to select the real-time data feed for my AMP platform setup to feed the data into Sierra Chart.
I can choose either Teton (Sierra Chart) or Sierra chart-Denali-CQG(No Data-Order routing only). Which should I choose? It's so misleading.
[2023-06-02 13:49:58]
Sierra_Chart Engineering - Posts: 25005
It depends. You need to ask your broker , did they set up your account on Teton order routing or CQG?
