Date/Time: Wed, 30 Sep 2026 00:27:30 +0000
Can I use the Teton-Registration at AMP to connect my Software VTT via AMP.
View Count: 577
| [2023-06-01 17:17:25] |
| User408639 - Posts: 83 |
Moin Moin. I had registered my Teton-Feed for Sierra-Chart at AMP-futures. The question is, whether this serves the purpose to allow using the Teto-Feed using any software via AMP (, whilst, of course, deactivating it for my "sierrachart64.exe"). If not, I do not see, why AMP does need to know, where Sierra-Chart is obtaining its data from, and why the took 2 days to approve something, they do not handle. But, if this is possible.: Do You have the Specs, because AMP does not know, what I am talking about. _Tschüß, __Michael. |
| [2023-06-01 17:18:23] |
P.S.: I had to change my Email-address at AMP to mine registered here. So they are checking some authentication.
| [2023-06-01 20:57:46] |
| John - SC Support - Posts: 48062 |
We are really not sure we understand your question. The data from Sierra Chart can not be used with any other system. It only works with Sierra Chart. Also, the Teton Order Routing Service only works with Sierra Chart. It does not work with any other system (it is our software). If you are wanting to use the Teton Order Routing Service, then follow the instructions at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
