Date/Time: Wed, 30 Sep 2026 00:27:11 +0000
subgraph to output ask and bid value in high or low bar
View Count: 716
| [2023-06-01 09:45:04] |
| User741988 - Posts: 14 |
Hi is there exist a study which output the value of the bid or ask at hte top or low of the bar? I try to compare between to charton the same Asset but with not the same bar period value, the ask value of the top bar, and the bid value of the low of the bar. I want a subgraph on the first chart wich output the bid or ask value of the low/top bar . Then, i can overlay this study (and this value) on the 2 nd graph and do comparaison. thanks for your support |
| [2023-06-01 10:58:25] |
| Sierra_Chart Engineering - Posts: 25005 |
Have a look at these studies: Bid & Ask Prices Study Subgraph Above/Below Bar as Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-01 10:58:45
