Date/Time: Wed, 30 Sep 2026 00:26:44 +0000
Service pack 5 - data feed included to trade FX and indicies?
View Count: 673
| [2023-05-31 12:29:24] |
| User137421 - Posts: 7 |
Hi, can you tell me if I need to have a separate data feed when trading S&P 500 index and FX please, I'm currently using service pack 5 at $36 per month, I'm not trading futures at this stage. Thanks for your help Pete |
| [2023-05-31 15:07:15] |
| John - SC Support - Posts: 48062 |
What S&P 500 Index are you referring to? The most popular is the ES Futures from the CME Group, but you state that you are not trading futures. Is this a CFD? Or something else?
| [2023-05-31 16:04:36] |
Hi yes it’s a cfd - do I need a separate live data feed to traded cfd and forex?
| [2023-05-31 17:01:32] |
| Sierra_Chart Engineering - Posts: 25005 |
You can chart these within Sierra Chart and do simulated trading of CFDs and Forex.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-31 17:02:17
| [2023-05-31 17:15:30] |
Do I need a data feed then so service pack 12 will be required? So no live data is supplied on service pack 5? |
| [2023-05-31 19:47:53] |
You can get the FOREX and CFD data on the Base packages. So you can get this data now without having to pay anything extra. Refer to the following: Sierra Chart Real Time and Historical Forex and CFD Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-06-01 11:27:29] |
Sorry I’m still confused - when I read the link you referee to it’s says- ‘Live Trading Services: No. For Forex and CFD trading use the LMAX Trading Service service.’ Does that mean that pack 5 doesn’t support live trading services - I just need to know what pack to select so I’m not overpaying please? |
| [2023-06-01 12:34:13] |
No Service Package 5 does not support live trading unless you are using Teton order routing and would be using delayed data. Who is your broker you will be trading through?
