Date/Time: Tue, 29 Sep 2026 23:46:18 +0000
service
View Count: 555
| [2023-05-30 09:59:21] |
| lilimas - Posts: 1 |
"Hello! I need a service for Binance. Do I need to purchase a service with data or can I use the Binance API and connect it to Sierra Chart?"
| [2023-05-30 09:59:28] |
| Sierra_Chart Engineering - Posts: 25005 |
Binance is supported. Refer to: Cryptocurrency / Bitcoin Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
