Date/Time: Tue, 29 Sep 2026 23:45:51 +0000
Trading issues
View Count: 575
| [2023-05-29 10:14:38] |
| User519648 - Posts: 3 |
Hi. I am experiencing difficulties with my stop and target command. For example when I set a stop and target command they done work. Is there someting that I need to do to prevent this as it can be quite costly.
| [2023-05-29 10:23:58] |
| Sierra_Chart Engineering - Posts: 25005 |
First refer to the information here regarding this: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
