Date/Time: Fri, 13 Nov 2026 23:26:40 +0000
Fix Request -
View Count: 722
[2023-05-28 17:33:50]
SavantTrader - Posts: 112
Dear SC Support:
In the Trade Window, the "Cancel All" button color does not properly paint the entire button.
Can you please add this to your "bug fix" list - it seems to have been overlooked.
See attached example (a picture is still worth a thousand words).
PS - The complete SUBJECT of this post was: Fix Request - "Cancel All" Button Color
It seems the board code did not like the quotes around the subject text, and truncated the subject instead of escaping the quotes.
Date Time Of Last Edit: 2023-05-28 17:36:50
imageCapture3.png / V - Attached On 2023-05-28 17:33:41 UTC - Size: 22.04 KB - 186 views
[2023-05-30 14:20:57]
The coloring you are seeing means that the button is "Not Available", or "Turned Off".
If you do not have any working orders that could be cancelled then the button will appear like this, or if you specifically turned it off.
[2023-05-30 14:30:17]
Sierra_Chart Engineering - Posts: 25424
This coloring is controlled by the operating system.
