Date/Time: Tue, 29 Sep 2026 23:46:18 +0000
[Programming Help] - custom study values not matching chart or spreadsheet
View Count: 563
| [2023-05-28 16:35:16] |
| $tack - Posts: 123 |
I am building a custom study in ASCIL and am calling the GetStudyArrayUsingID method to access values in separate custom studies/subgraphs. The issue I'm having is that I'm printing out all the values for all subgraphs it's returning and they don't match what I'm seeing in the chart, or the values I see when I create a spreadsheet study. The subgraphs show the value of the current price when the signal fires, and zero if not. However I either just see zero for all the values for the subgraph, or in some cases I see a float value below 1 that I don't see anywhere on the chart/spreadsheet. Is there a reason why the values through ascil would be different? I do not have access to the other custom study code to see what it's doing to determine further what is happening. Is there a workaround for this such as using another builtin study to reference the values of the custom study and then referencing those values? Any advice is appreciated. Thanks in advance |
| [2023-05-28 16:36:33] |
sorry i'm not sure if it matters if i should post this as a support request or a user discussion and accidentally submited as user discussion. I can resubmit as support request if needed.
