Date/Time: Tue, 29 Sep 2026 23:46:19 +0000
Sub-instances from main only? Option used to be greyed out in sub-instances, not anymore?
View Count: 556
| [2023-05-26 23:16:38] |
| User34124 - Posts: 289 |
Am I right in believing the below from the documentation is not relevant due to new updates?: Instructions For Sharing Data Using Sub Instances (Easiest And Recommended Method) Start another instance of Sierra Chart by selecting File >> New Instance in an existing running instance of Sierra Chart. This can only be done from the main instance of Sierra Chart, not a sub-instance. |
| [2023-05-29 15:44:50] |
| Sierra_Chart Engineering - Posts: 25005 |
You can only do this in the main instance of Sierra Chart.
