Date/Time: Tue, 29 Sep 2026 23:46:18 +0000
Order Fills Not Aligning to Bars on Chart
View Count: 605
| [2023-05-25 20:05:51] |
| User538557 - Posts: 1 |
Good Day, Recently my order fills are not aligning correctly on my chart. Pleae refer to screenshot. As you can see the first fill is not even aligned to a bar on the chart, likewise for the rest of them. Please can i get some assistance with this, i don't know how this has happened as it was fine a few weeks ago. I have re-downloaded all the chart data, but still issue occurs Many Thanks. |
| [2023-05-25 20:56:42] |
| John - SC Support - Posts: 48062 |
There are two possibilities. One possibility is the time stamping is not correct for the order fills. Refer to the following: Trade Activity Log: Inserting and Editing Order Fills Another possibility is maybe the Scale Range of the chart is not set to Automatic. Refer to the following: Chart Scale and Scale Adjusting: Automatic (Scale Range) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
