Date/Time: Sun, 01 Nov 2026 04:59:36 +0000
Historical Data
View Count: 1390
| [2014-06-27 17:17:31] |
| sam849 - Posts: 1 |
Hello, Is there a way to create a report that listed historical data of a chart including indicator values? Regards... |
| [2014-06-27 17:35:47] |
Yes. This can be done through the Spreadsheet study: http://www.sierrachart.com/index.php?l=doc/doc_SpreadsheetStudy.html The spreadsheet can be saved to a text file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
