Date/Time: Fri, 13 Nov 2026 23:16:42 +0000
how to cancel working position OR flatten a position automaticly based on alert study
View Count: 604
| [2023-05-22 12:49:27] |
| pvt2020 - Posts: 5 |
Hi anyone, or sierrachart support, could you guys tell me if it is possible to cancel a working position or flatten position based on alert in study, if yes could you point me to the right documentation, as i have no found anything related. Thank you Best Regards basic example vwap negative alert > cancel active working order |
| [2023-05-22 14:06:37] |
| Sierra_Chart Engineering - Posts: 25424 |
You could modify the Trading System Based on Alert Condition study to do what you need: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
