Date/Time: Fri, 13 Nov 2026 23:16:40 +0000
Chartbooks
View Count: 933
| [2023-05-22 11:23:38] |
| User540334 - Posts: 1 |
I have two separate Chartbooks that I'd like to combine together because understanding all of my settings to be put on one of the other Chartbooks would be a waist of time. Is there an option to merge Chartbooks into one?
| [2023-05-22 12:42:15] |
| JohnR - User831573 - Posts: 340 |
Under the Chart Menu item, there is the ability to Duplicate one or All charts to a Chartbook Hope this helps, JohnR |
| [2023-05-22 14:05:40] |
| Sierra_Chart Engineering - Posts: 25424 |
Refer to: Chartbooks (Workspaces): Combining Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
