Date/Time: Sun, 01 Nov 2026 04:58:32 +0000
Volume at Price Help
View Count: 1545
| [2014-06-27 13:09:58] |
| User24187 - Posts: 54 |
On the settings, I see an option to view volume per bar as a % of max volume bar. However, is there a way I can view it as a % of Total Volume?
| [2014-06-27 16:51:02] |
We will add this option.
| [2014-06-28 01:09:00] |
This has been implemented and will be out in the next release.
